Bec proiector
Bec proiector
Are careva idee caum se schimba becul la proiector, asta ca sa scutesc un drum la service
KIA CEED 2.0 GSL-143CP- ESP,Clima,Jante17'',Senzori parcare,etc
http://www.youtube.com/watch?v=SlBAVJjTwVk
+++ASTRA GTC 1.6T-180CP-ROSU
kia
Este vb. de proiectorul de drum (faza lunga ),sau de ceata ?
Gasesti aici. http://58.87.51.38/kme_viewer/
[/url]HEAD LAMP RELAY / FRONT LAMP RELAY1. Disconnect the negative(-) battery terminal.
2. Pull out the relay from the engine compartment relay box.
A : Head lamp(Low) relay
B : Head lamp (High) relay
3. Check for continuity between terminals. There should be continuity between the No.87 and No.30 terminals when power and ground are connected to the No.86 and No.85 terminals.
4. There should be no continuity between the No.87 and No.30 terminals when power is disconnected.
TAIL LAMP1. Disconnect the negative(-) battery terminal.
2. Remove the crash pad lower panel.
(Refer to the Body group - "Crash pad")
3. Remove the junction box.
4. Check for continuity between the terminals.
(1)
There should be continuity between the No.2 terminal in the I/P-H and the No.15(LH) or 4(RH) terminal in the I/P-G when power and ground are connected to the No.2 terminal in the I/P-H and the No.6 terminal in the I/P-D.
(2)
There should be no continuity between the No.2 terminal in the I/P-H and the No.15(LH) or 4(RH) terminal in the I/P-G when power and ground are connected to the No.2 terminal in the I/P-H and the No.6 terminal in the I/P-D.
HEAD LAMP ESCORT1. If Head Lamp is lighting by Head Lamp SW or AUTOLIGHT, Head Lamp lighting is maintained when IGN1 is changed ON to OFF.
2. Following stste, Head Lamp lighting is truned off.
But, TAIL LAMP keep up lighting when KEY IN in the condition of lighting off after IGN ON→OFF and lighting.
(the condition of TAIL LAMP lighting off follows TAIL LAMP AUTOCUT function.)
A. When Driver DOOR SW OPEN→CLOSE and after 30sec.
B. When Head Lamp SW ON or not the case of AUTO LIGHT SW ON.
(ALC ; When Head Lamp ON, Head Lamp SW ON within Multi-function SW during ESCORT → Lighting keeping up when SW is moned to AUTO LIGHT SW ON or reverse.)
C. When Driver DOOR OPEN state is maintained after 5minute.
D. When IGN1 ON→IGN OFF and sfter 5minute.
E. When received TX LOCK signal two times during output.
1) Head Lamp RELAY output of TIMING CHART contains the condition of TAIL LAMP ON.
2) Head Lamp RELAY output by - Head Lamp SW and HEAD LAMP RELAY output by AUTO LIGHT is regarded identical condition.
That is, the explaining of HEAD LAMP RELAY ouput contains two cases.
3) AUTO LIGHT SW ON : HEAD LAMP&TAIL LAMP signal by AUTO LIGHT is output.
4) AUTO LIGHT SW OFF: HEAD LAMP&TAIL LAMP signal by AUTO LIGHT is not output.
ADJUSTMENT
HEAD LAMP AIMING INSTRUCTIONS
The head lamps should be aimed with the proper beam-setting equipment, and in accordance with the equipment manufacturer's instructions.
If there are any regulations pertinent to the aiming of head lamps in the area where the vehicle is to be used, adjust so as to meet those requirements.
Alternately turn the adjusting gear to adjust the head lamp aiming. If beam-setting equipment is not available, proceed as follows :
1. Inflate the tires to the specified pressure and remove any loads from the vehicle except the driver, spare tire, and tools.
2. The vehicle should be placed on a flat floor.
3. Draw vertical lines (Vertical lines passing through respective head lamp centers) and a horizontal line (Horizontal line passing through center of head lamps) on the screen.
4. With the head lamp and battery in normal condition, aim the head lamps so the brightest portion falls on the horizontal and vertical lines.
Make vertical(A) and horizontal(B) adjustments to the lower beam using the adjusting wheel.
FRONT FOG LAMP AIMING
The front fog lamps should be aimed as the same manner of the head lamps aiming.
With the front fog lamps and battery normal condition, aim the front fog lamps by turning the adjusting gear (A).
HEAD LAMP AND FOG LAMP AIMING POINT
1. Turn the low beam on with driver.
The cut-off line should be projected in the allowable range.
In case of equipping with the manual leveling device, set the leveling device switch on the "O" position.
In case of equipping with the auto leveling device, set the initialization by using the diagnostic tool before aiming.
2. Turn the high beam on with driver.
The hot point should be projected in the allowable range.
3. Turn the front fog lamp on with driver.
REMOVAL
1. Disconnect the negative (-) battery terminal.
2. Remove the radiator grille upper cover(A).
3. Loosen the mounting bolts (2EA) and nut(1EA) of head lamp. Remove the head lamp assembly (A) after disconnecting the lamp connectors.
Take care that retaining clip (A) is not to be damaged.
4. Remove the bulb caps from the head lamp assembly.
A : Head lamp high bulb & position bulb cab
B : Head lamp low bulb cab
C : Turn signal bulb cab
5. Remove the head lamp bulbs.
INSTALLATION
1. Install the head lamp bulbs.
2. Install the head lamp bulb caps.
3. Install the head lamp assembly after connecting the lamp connector.
(1)
(2)
ADJUSTMENT
REMOVAL
INSTALLATION
Nu este vb de proiectorul de ceata, fata
kme_viewer
2007 > Engine > 1.4 G'>Cee'd [ED] > 2007 > Engine > 1.4 G
Body electrical system/ Lighting System/Fron Fog Lamps/Repair Procedure
Spor!
Spor!
Imi cer scuze, dar nu am inteles. Ia ma usor pls. Ms
Bec
Intra pe aceasta adresa si din aproape in aproape o sa gasesti schimbarea becurilor folosind si trimiterile lui akbhar adica :Body electrical system/ Lighting System/Front Fog Lamps/Repair Procedure
Din desene si explicatii am inteles ca s-ar suspenda masina ptr. a ajunge mai usor in spatele barei de protectie unde se roteste suportul becului spre stinga .
http://58.87.51.38/kme_viewer/dispimg.a ... e7469l.gif
Intra pe adresa de mai sus care te va duce la imaginea din spate a proiectorului.
In link e un fisier PDF cu intructiunile de pe http://58.87.51.38/kme_viewer/
fog-lights
kme_viwer e un site cu manualul tehnic pentru modele produse de Kia.
fog-lights
Multumesc, am sa intru si sper sa inteleg.Ms
Eu zic ca am ajuns acolo unde ati spus voi, dar nu ma ajuta cu numic. In primul rand ca nu mi arata modelul meue modelul veci de Sportage) iar in al 2 lea rand nu zice nimik de proiector de ceata.
Poate nu am ajuns unde trebuie
Aaaaaaaaaaaaa, ce gura casca sunt........
Am fost neatent si am presupus by default ca e vorba de Cee'd-ul din semnatura.
Pai nu e nici o prolema. Din ce an e Sportage-ul?
Accesezi http://58.87.51.38/kme_viewer/.
In tabelul care apare dai scroll in jos pana ajungi la Sportage si dai click pe un Yes din dreptul anului de fabricatie dorit. In stanga va apare o lista cu toate motorizarile existente si cu diversele subansamble. Navighezi la Body Electrical System/Lighting System/Fog Lights si acolo sunt intructiunile de inlocuire.
Vad totusi ca pentru modelele pre 2005 nu exista instructiuni de schimbare a becurilor de la proiectoare.
Pai da, este vorba de yltimul model de sportage, cel din poza
Bun, acum ca ne-ma lamurit cu moelul sa vedem.
Deci pentru un Kia Sportage modelul nou intrsuctiunile ar fi astea:
http://58.87.51.38/kme_viewer/content.a ... procedures
Din pacate se pare ca trebuie data bara fata jos, adica:
Spor la treaba!
Spor la treaba!
Sarut mana mult de tot, pt interes
Ma duc la service,este mult prea complicat, ca ma streseaza rau de tot ca nu merge un bec
oricum inca o data ms pt promtitudinea si interesul acordat
