Jante si anvelope Sportage
Flavyus
Re: jante kia sportage
Post by Flavyus »
Arata bine Hankook, imi place profilul longitudinal, asa am avut Continental de iarna dar au renuntat la model.
Alexes
Auto: Kis Sportage
Post by Alexes »
Au cel mai bun pret din cate am vazut, discount de 20%.
Flavyus
Post by Flavyus »
Cu acel profil sunt foarte bune de sosea iarna, dar suficient de bune di pe zapada.
B575DAG
Auto: Sportage 1.7 DSL
Post by B575DAG »
Știe cineva codul jantelor noi de pe Facelift? Cele cu negru din prezentarea oficială ....
Kia Sportage 1.7 DSL Style
akeem
Post by akeem »
Continentalurile nu trebuiau sa aiba si un SUV la coada? Stiu ca flancurile sunt un pic mai ranforsate si acum am gasit si asta:
The tyre’s designers reinforced its carcass to cope with any type of road and to successfully transfer large forces present when cornering, acceleration and braking. Its tread blocks are larger than those on the Continental WinterContact TS 850 P, which is designed for smaller cars. This enables faster tyre cleaning on difficult terrain and prevents the 'catching' of stones between the tread grooves. The number of blocks has been also increased, which provides more side edges across the tire. This improves grip and stability in snow and slush. As a result, traction is better by up to 5% compared to previous winter tyre models
Read more: https://www.oponeo.co.uk/tyre/continent ... -850-p-suv
The content above is the exclusive property of Oponeo.co.uk Ltd.
Asta e prima chestie.
A doua, ar trebui sunat la Anveloshop pentru DOT , inainte de comanda. Eu am mai luat de la ei un set de TS860 pentru Sandelul lui socru-meu si cand l-am sunat mi-a zis ca au DOTuri din feb si martie 2017. Totusi un an si ceva de stat cine stie pe unde....
Alexes
Auto: Kis Sportage
Post by Alexes »
Intr-un final am ales sa merg pe Hankook.
https://www.best-tires.ro/anvelope-iarn ... 0-99h.html
Livrare 2 zile, foarte ok.
proc74
Auto: Ceed/Sportage
Post by proc74 »
Eu pe astea le am: https://www.anvelino.ro/iarna/5050539-a ... compari.ro. Am fost foarte multumit iarna trecuta, folosindu-le in regim urban.
Sportage 1.6GDI Style+
Ex.Ceed best - kompass blue
CT 12 BNK
oro
Auto: Kia Sportage 2018 FL
Post by oro »
Buna. Am o intrebare: pot monta pe un Sportage 2018 FL jante cu caracteristica 7Jx18 ET 40,5? Mentionez faptul ca anvelopele 225/55/R18 le am trecute in CIV. Multumesc.
ovidiu.anica
Auto: Kia Sportage GT Line 1.6 T-GDI
Post by ovidiu.anica »
@oro Foarte interesant cum de ai tu in civ jantele de 18. Sunt pe certificatul de conformitate pt Sportage 2018? Intreb pt ca pe 2017 nu sunt si RAR nu le trece :(
Merci,
Ovidiu
oro
Post by oro »
In CIV, la mentiuni, am 3 dimensiuni: 215/70/R16, 225/60/R17, 225/55/R18, trecute si in certificatul de conformitate.
ovidiu.anica
Foarte dragut din partea lor, merci de info :)
CostynNE
Auto: SorentoPrem 1.6 T-GDI PHEV 4x4
Post by CostynNE »
Salutare. Va cer si eu o parere. Credeti ca e ok sa folosesc pt o iarna jantele primite de la producator(cele de 16” din aliaj) cu niste anvelope de iarna cu aceleasi dimensiuni ca cele de vara(adica 215/70/r16)? Urmand ca iarna urmatoare sa achizitionez niste jante de tabla tot de 16”?
Multumesc frumos!
Flavyus
Post by Flavyus »
Adica dejantezi si inlocuiesti anvelopele, se poate. Dar atentie la senzori cand umbla la jante !
Megahertz
Auto: KIA Sportage 2021 FL 1,6 T-GDI
Post by Megahertz »
Adica ? :)
CostynNE
Post by CostynNE »
@Flavyus, ms pt raspuns. Ma interesa mai mult partea cu dimensiunile. Daca e ok sa merg pe aceleasi dimensiuni si pe anvelopele de iarna.
Si daca tot ai pomenit de senzori- eu am acum un Golf7 cu TPMS(sper sa nu ma insel cu prescurtarea) la care fac asta in fiecare iarna/vara, am doar un set de jante si schimb anvelopele de fiecare data. Nimeni, niciodata nu mi-a spus de acei senzori-este posibil oare sa se foloseasca alta tehnologie pe VW? Ma refer ca poate nu foloseste acelasi sistem de monitorizare al presiunii din anvelope prin senzori!? Daca sunteti draguti sa ma lamuriti...as aprecia....
