Vand subwoofer activ JBL E250P
Posted: 27 Jun 2012, 14:15
Vand subwoofer activ (amplificator incorporat) JBL Northridge E250P nefolosit.
12'' 250Watt Powered Subwoofer (230V)
Caracteristici:
Culoare: cherry
Putere RMS: 250W
Peak Dynamic Power: 550 Watts (The Peak Dynamic Power is measured by recording the highest center-to-peak voltage measured across the output of a resistive load equal to minimum impedance of the transducer, using a 50Hz sine wave burst, 3 cycles on, 17 cycles off).
Diametru difuzor: 30cm (Low-Frequency Transducer: 12" PolyPlas)
Inputs: Line Level (switchable to LFE) and Speaker Level with 5-way binding posts
Raspuns in frecventa: 25 - 150Hz (Low-pass crossover setting)
Filtru LPF (Low Pass Frequency) variabil: 50 - 150Hz
Dimensiuni: 502mm x 365mm x 419mm
Greutate: 19.5kg
Pret: 200 euro negociabil.
Contact: PM
Caracteristici:
Culoare: cherry
Putere RMS: 250W
Greutate: 19.5kg
Contact: PM
