Daca adaugam si diferenta de 1.080 Eur cu tva pentru acesti 48 CP ...devine o chestiune subiectiva .
O comanda deja intrata in luna de productie nu se modifica .
As putea face o concluzie in privinta consumului pt. 2.0 D - 136 CP : cutie manuala mixt cca 7 % / automata cca 8.5 % ( am facut o medie a autoturismelor care vin la service si parerile posesorilor ) .[/quote]
1.In ce sens, la consum?Cat are Hyundai-ul consum?
2.Nu am fost anuntat cum ca masina ar fii intrat in productie(pentrtu ca m-ar fii sunat sa merg cu diferenta de bani).Astfel, ma gandesc ca s-ar putea aduce unele modificari la comanda,nu?
3.Sigur ar fii vorba despre o softare doar? Eu speram sa fie vorba despre Sportage R sau asta:
a)http://en.wikipedia.org/wiki/Hyundai_R_engine
b)Despre asta vorbeam eu, cel putin speram ca asta presupune acea optiune:
http://kia-buzz.com/?p=5387 ...pe asta chia nu m-as supara sa dau 1000e in plus.Daca nu e asta, nu mai are rost discutia
altele
c)2011 KIA SPORTAGE-R 2.0 E-VGT LX 4WD
Specs of KIA SPORTAGE-R 2.0 E-VGT LX 4WD, manufactured or sold in 2011, version for Asia Korea DM(sa fie asta si la noi?) with 5-door wagon body type, 4x4 on-demand (100% front drive in normal conditions, rear engaged automatically when front wheels slipping is detected, 50/50 Lock Mode engaged manually in off-road conditions up to 25mph/40km/h speed) and manual 6-speed gearbox. Basic specs and characteristics: diesel engine of 1995 cm3 / 121.8 cui displacement with advertised power 135 kW / 181 hp / 184 PS ( JIS net ) / 4000 and 392 Nm / 289 lb-ft / 1800 of torque. Dimensions: this model outside length is 4440 mm / 174.8 in, it’s 1855 mm / 73 in wide and has wheelbase of 2640 mm / 103.9 in. The officially claimed value of a drag coefficient Cd = 0.37 . Standard wheels were fitted with tires size 215/70 R 16 H. Reference vehicle weights are: official base curb weight 1590 kg / 3505 lbs . How fast is that car ? Performance: top speed 197 km/h (122 mph) (theoretical); accelerations 0- 60 mph 8.2 s; 0- 100 km/h 8.7 s (a-c simulation); 1/4 mile drag time (402 m) 16.3 s (a-c simulation). Fuel consumption and mileage: official: 6.2 l/100km / 45.5 mpg (imp.) / 37.8 mpg (U.S.) / 16.1 km/l , average estimated by a-c: 7.7 l/100km / 37 mpg (imp.) / 30.8 mpg (U.S.) / 13.1 km/l . To view table with this car complete performance data and technical specifications (including final drive and gear ratios, powertrain description, inside and outside dimensions, acceleration graphs etc.) and more photos, or to compare up to 5 cars side-by-side - click one of the the buttons below...
Luat de aici :http://www.automobile-catalog.com/make/ ... /2011.html
d)Aici apare un motor diferit R : http://www.kiamotors.com/vehicles/sport ... ation.aspx
PS: Am sa deschid un topic nou pe tema asta...am scris aici doar asa, ca si raspuns, sa il gasesti.
Mersi frumos de ajutor si, daca p[oti, fa putina lumina in privinta asta pt ca nimeni nu stie nimic despre asta.Mersi mult
